Once your folder structure is in place and your content designers have user accounts, you can grant folder access to those designers. Folder access specifies the folder in which a user or application group can create and control automation objects. This procedure assumes that you are assigning a separate folder to each content designer and that these folders are directly under the root folder.
A custom policy based on Object lets you grant folder access to specified users or groups. Available access rights to folders include List, Read, Edit, Delete, and Admin. After you create the first policy, you can use that policy as a template for creating other policies.
A New Access Policy appears where the Resource Class Name is Object.
The name appears in the Selected Identities list prefaced by [User].
Your entry appears in the Resources list
The saved policy resembles the following:
Note: To grant read access to all folders, create a policy with Object to which you add all content designers. Select Object_List and Object_Read for the root folder.
