You create a folder in the left pane of the Library tab. The left pane is the navigation pane for the library. A folder contains the content that content designers design from automation objects. All objects that support a specific automated process must be in the same folder or same folder structure for export. It is convenient to create a root-level folder for each project.
Within a process-level folder, you can create subfolders. At export time, the folder that you export as a content package cannot contain any unused or obsolete objects. The folder structure that you establish for a project in the design environment is replicated in the production environment upon import.
You can create a folder under the root node or under an existing folder.
The folder path appears in the main pane with a field for the name. The default name is displayed as Folder.
