The actions that are selected on predefined CA EEM policies grant permissions to tabs, palettes, folders, and automation objects. The following tables describe the permissions that each action grants to groups (identities) in the corresponding resource policies.
If you create custom policies from these resource classes, use the corresponding tables as a guide for assigning permissions.
Home Tab
Action Key |
Resource Class for Policy |
Permissions |
Console_Login |
Product User |
Log in to CA Process Automation and use the Home tab. |
Library Tab
The following table lists permissions in order from the lowest level to the highest level. To view the Library tab, you must have the LibraryBrowser_User permission and either the Environment_Library_User or the Environment_Library_Admin permission. For more information, see Permissions Dependencies.
Action Key |
Permissions |
LibraryBrowser_User |
LibraryBrowser |
View access to the Library tab. |
Object_List |
Object |
Environment_Library_User |
Environment |
Prerequisite to many Operations tab permissions.
Object_Read |
Object |
Navigate a folder path and open any automation object in the corresponding designer orviewer. Implicit: List |
Object_Edit |
Object |
Edit a folder or an automation object in a folder. Implicit: Read, List |
Object_Delete |
Object |
Delete a folder or delete an automation object added to a folder. Implicit: Edit, Read, List |
Object_Admin |
Object |
Create a folder or any automation object. Implicit: Delete, Edit, Read, List |
Environment_Library_Admin |
Environment |
Create, Delete, Edit, Read, and List on all automation objects in the Library tab. |
Group_Config_Admin |
Group Configuration |
Access Group Config tab. See Permissions on Automation Objects for permissions granted on custom operators. |
Designer Tab
Users with access to the Designer tab are typically also granted access to the Library tab. Designers need at least the following Library tab permissions to save a process they are designing:
Action Key |
Permissions |
Designer_User |
Designer |
View access to the Designer tab. |
Operations Tab and Palettes
Designers require access to the Operations tab in the design environment; production users require access to the Operations tab in the production environment. To view the Operations tab, you must have either the Environment_Library_User or the Environment_Library_Admin permission. For more information, see Permissions Dependencies.
Action Key |
Permissions |
Operations_Process_Watch |
Operations |
Process_Monitor |
Process |
Implicit: List |
Process_Start |
Process |
Start a process instance. Implicit: Monitor, List |
Process_Control |
Process |
Suspend, restart, resume, or abort process instances. Implicit: Start, Monitor, List |
Operations_Schedules |
Operations |
View Active Schedules link in the Operations tab. |
Agenda_Control |
Agenda |
Activate and deactivate a schedule on a touchpoint. Implicit: Read, List |
Operations_Datasets |
Operations |
Open the Operations tab Datasets palette. |
Dataset_Inspect |
Dataset |
View a dataset object and read the variable values in the dataset. Implicit: List |
Dataset_Modify |
Dataset |
Create, Edit, and Delete the dataset object. Implicit: Inspect, Read, List |
Operations_Resources |
Operations |
Open the Operations tab Resources palette. |
Resources_Control |
Resources |
Operations_User_Requests |
Operations |
Open the Operations tab User Requests palette. |
Operations_Content_Packages (Content Packages) |
Operations |
Open the Operations tab Content Packages palette. |
Operations_Task_List |
Operations |
StartRequestForm_Dequeue |
Start Request Form |
Dequeue a process that a start request form put in the queue. Implicit: Start, List |
StartRequestForm_Start |
Start a task that a start request form defines. Implicit: List |
Execute |
TouchPoint Security |
Run scripts or programs in operators. The product derives the impacted operators from specified operator categories. The impact occurs when the target is a specified touchpoint in a specified environment. |
Reports Tab
The following table lists the action relevant to using the Reports tab.
Action Key |
Permissions |
Reports_User |
Reports |
Configuration Tab and Palettes
The following table lists the actions that impact permissions on the Configuration tab. To view the Configuration Browser on the Configuration tab, you must have the Client_Configuration_User permission. For more information, see Permissions Dependencies.
Action Key |
Permissions |
Client_Configuration_User |
Configuration Browser |
View the Configuration tab Configuration Browser. |
Environment_Configuration_Admin |
Environment |
Domain_Admin |
Domain |
Configuration_User_Resources |
Open the Configuration tab Manage User Resources palette and update the User Resources folder contents. |
Configuration_Installations |
Open the Configuration tab Installation palette and start installing an agent, Orchestrator, or cluster node of an Orchestrator. |
