Users with Domain Administrator permissions can upload resources to the Agent Resources folder on the Domain Orchestrator. The uploaded resource can be a jar file, for example, a JDBC driver. The uploaded agent resources are mirrored at the configured mirroring interval. After mirroring occurs, you restart the agents. Restarted agents can use the uploaded agent resources.
The Add New Resource: "Untitled" pane opens
If you are uploading a JDBC driver, type database_name Driver; where database_name is the RDBMS. For example, Oracle Driver, MySQL Driver, or Sybase Driver.
This populates the Resource File field with the file and its path.
A line with your entry displays.
CA Process Automation copies the uploaded resources, for example, a JDBC driver, to the following path, where install_dir is the directory on the server where the Domain Orchestrator was installed.
install_dir/server/c2o/.c2orepository/.c2oagentresources/lib/drivers/jars
Note: See How to Start or Stop an Agent for details on restarting agents.
