You can configure properties of a host group within the Configuration tab. You establish connectivity between the agent and each remote host in the host group with third-party products.
If the agent host has a Windows operating system, enter:
C:\PAM\SshKeys
If the agent host has a UNIX or Linux operating system, enter:
/home/PAM/Sshkeys
Important! Create the target path on the agent host.
See How to Define Remote Host Name Patterns using Regular Expressions.
Note: If you configure public key authentication, this value must be specified as the user-name in the command to generate key files. If using public key authentication with a passphrase, enter the passphrase for Remote Password.
Configuring properties is part of the total configuration. You must create a user account on each remote host with the credentials you configured here. This provides SSH access from the agent to each remote host in the host group. Establishing a trust relationship with public and private keys is optional.
