Audit User Actions › View the Audit Trail for an Environment
With Configuration Administrator access rights, you can view the Environment audit trail.
The Environment audit trail monitors the following actions:
- Environment is locked or unlocked.Environment property is changed.
- Environment is created or deleted.
- Environment or object in the Environment is renamed.
- Touchpoint is added, deleted, or renamed.
- Touchpoint Group is added or deleted.
- Host Group is added or deleted.
- Click the Configuration tab.
- On the Configuration Browser palette, expand the Domain node and select the Environment to audit (for example, the Default Environment).
- In the Contents pane, click the Audit trails tab.
The Audit Trails tab displays the following information for all records:
- Object Name
- Last Updated
- Username
- Action Type
- Description
- (Optional) To sort the audit trails by a specific column, select Sort Ascending or Sort Descending from the target column drop-down list.
For example, to audit a specific user, select a sort option from the Username column drop-down list, and then scroll to the appropriate record.
- (Optional) To change the number of records that the product displays on a page, select a value from the Rows On Each Page drop-down list.
- Examine the records in the audit trail.
If the audit records comprise multiple pages, use the toolbar navigation buttons to display the first page, previous page, next page, or last page.
