If you want to make public key authentication available for use, create a trust relationship from the proxy touchpoint host to the target remote host. Then, test SSH connectivity from the computer running the proxy touchpoint to the target computer. A trust relationship is created between two host computers.
CA Process Automation uses the public key authentication that you configure only if user/password authentication fails.
To create a trust relationship, use the ssh-keygen program to generate the private and public key pair. The private key stays on the host with the agent. Copy the public key to the target remote host that has no agent.
ssh-keygen -t dsa -b 1024 -f user_name
You are prompted for a passphrase to use later as a password.
The private key file named user_name and the public key file named <user_name>.pub are created.
The key is accessed from this directory with any host for which there is no target_host_name/user_name file.
The SSH Keys Path option specifies the location for the private keys directory in the proxy touchpoint properties dialog.
Different SSH daemons follow different conventions. Examine the ssh-keygen options for details such as formatting requirements for the public key file.
cat user_name.pub >> ~user_name/.ssh/authorized_keys
