Administer Touchpoints › Set up Touchpoints for Design and Production › Configure Properties for the Design Touchpoint
You configure properties for a touchpoint based on the environment. For touchpoints associated with a design environment, you have the option of recovering operators manually. This setting provides you with the better opportunity for troubleshooting. Touchpoint security typically targets mission critical hosts and is typically not applicable to any agent host used during design.
- Click the Configuration tab.
- Right-click the environment with the touchpoints to configure, and then select Lock.
- Expand the environment, and then expand All Touchpoints.
- Select the touchpoint to configure, and then click the Properties tab.
- Set the Autorecovery of Operators property to allow you to recover operators manually. This setting gives you optimal control over recovering operators when required.
- If an active Touchpoint Security policy protects this touchpoint, enable the Touchpoint Security property.
Enabling the property enforces the applicable policy that specifies the users that are allowed to run operators on the current target.
- Click Save.
- Right-click the environment, and then select Unlock.
