Overview for Administrators › Security › Suspending or Disabing a User Account
You can suspend or disable a user account in the following cases:
- The user no longer needs access to CA Process Automation but the user record must be retained for auditing purposes.
- You have reasons to prevent the specified user from accessing CA Process Automation temporarily or permanently.
- The predefined credentials made available to you at installation now represent an internal security threat. Because the credentials for the pamadmin and pamuser are documented, it is a good practice to make them unavailable after they have served their purpose.
- Log on to CA EEM.
- Click Manage Identities.
- Under Search Users, select Application User Details and click Go.
- Click the name of the target user.
- Scroll to the Authentication area and take one of the following actions:
- Click Suspended
- Click Disable Date, select the date at which the disable is to take effect, and click OK.
- Click Save.
Note: You can also reverse the suspension or enable a disabled account. You can use the disable/enable feature to defer the availability of a new account to the time you specify.
