Associate an existing touchpoint with a different agent in cases such as the following:
Here, the touchpoint is associated with only one agent and that agent is installed on a host scheduled for decommission. If a touchpoint is associated with multiple agents, no action is needed.
Here, the process references a touchpoint that must be associated with an agent installed on a host in the new data center.
Changing the agent association for a selected touchpoint involves deleting the current agent association and then adding a new agent association. To run a tested process on multiple hosts, associate the same referenced touchpoint to the agent that runs on each target host.
You can replace the agent association for a given touchpoint.
The Agents tab in the main pane lists the agent or agents currently associated with the selected touchpoint.
The agent touchpoint is removed from the list.
The Add agent reference to: touchpointName appears with a list of all agents. Active agents are displayed in Green.
The new agent to be associated with the selected touchpoint appears on the list in the Agents tab.
The selected touchpoint is now associated with a different agent.
