The table below lists the corresponding type of data that is used for the views for each time range that can be selected for a dashboard. For example, if you were to access a CPU utilization view for "Current Week", the Hourly rollup data would be used in the view.
Time Range |
Data Used in Views |
Today |
As polled |
Yesterday |
As polled |
Last Hour |
As polled |
Last 4 Hours |
As polled |
Last 8 Hours |
As polled |
Current week |
Hourly rollup |
Previous week |
Hourly rollup |
Last 24 Hours |
Hourly rollup |
Last 7 Days |
Hourly rollup |
Last 14 Days |
Hourly rollup |
Current month |
Daily rollup |
Previous month |
Daily rollup |
Last 30 Days |
Daily rollup |
Last 3 Months |
Daily rollup |
Last 12 Months |
Weekly rollup |
Note: When you choose to override the default resolution value for a view, the mappings that are shown in the table may no longer apply. For example, with the time range set to Last 24 Hours, the default resolution is 1-Hour, and the resulting view by default uses Hourly rollup data. However if you choose to override the default resolution to 5-Minute, the view uses as polled data.
