Installing Your Product from Pax-Enhanced ESD › Copy the Product Pax Files into Your USS Directory › Download Files to Mainframe through a PC
If you download pax or zip files from CA Support Online to your PC, use this procedure to upload the pax file from your PC to your z/OS USS directory.
- Follow the procedures in How the Pax-Enhanced ESD Download Works to download the product pax or zip file to your PC. If you download a zip file, first unzip the file to use the product pax files.
The pax or zip file resides on your PC.
- Open a Windows command prompt.
The command prompt appears.
- Customize and enter the FTP commands with the following changes:
- Replace mainframe with the z/OS system IP address or DNS name.
- Replace userid with your z/OS user ID.
- Replace password with your z/OS password.
- Replace C:\PC\folder\for\thePAXfile with the location of the pax file on your PC.
- Replace yourUSSESDdirectory with the name of the USS directory that you use for ESD downloads.
- Replace paxfile.pax.Z with the name of the pax file to upload.
The pax file is transferred to the mainframe.
Copyright © 2012 CA.
