Use this process to download a pax file from the CA Support Product Downloads window by running batch JCL on the mainframe. Use the sample JCL attached to the PDF file as CAtoMainframe.txt to perform the download.
Important! To simplify the Pax-Enhanced ESD process, the PDF version of this guide includes a sample JCL job that you can copy directly to the mainframe. To access this job, click the paper clip icon at the left of the PDF reader. A window displaying attachments opens. Double-click the file to view the sample JCL.
Note: We recommend that you follow the preferred method as described on CA Support Online. This procedure is our preferred download method; however, we do include the procedure to download to the mainframe through a PC in the next section.
The job points to your profile.
The job points to your email address.
The job points to your USS directory.
You have identified the product component to download.
Note: For multiple downloads, add files to a cart.
The Download Method window opens.
The Review Download Requests window displays any files that you have requested to download.
Note: We send you an email when the file is ready to download or a link appears in this window when the file is available.
Uses CA Technologies worldwide content delivery network (CDN). If you cannot download using this method, review the security restrictions for servers that company employees can download from that are outside your corporate network.
Host Name: ftp://ftpdownloads.ca.com
Uses the original download servers that are based on Long Island, New York.
Host Name: ftp://scftpd.ca.com for product files and download cart files and ftp://ftp.ca.com for individual solution files.
Both methods display the host, user name, password, and FTP location, which you then can copy into the sample JCL.
Note: The following links provide details regarding FTP: the FTP Help document link in the Review Download Requests window and the Learn More link available in the Download Methods window.
Important! If your FTP commands are incorrect, it is possible for this job to fail and still return a zero condition code. Read the messages in the job DDNAME SYSPRINT to verify the FTP succeeded.
After you run the JCL job, the pax file resides in the mainframe USS directory that you supplied.
Copyright © 2012 CA.
