Installing Your Product from Pax-Enhanced ESD › How to Install a Product Using Pax-Enhanced ESD
This section describes the Pax-Enhanced ESD process. We recommend that you read this overview and follow the entire procedure the first time you complete a Pax-Enhanced ESD installation. For experienced UNIX users, the Pax-Enhanced ESD Quick Reference Guide has sufficient information for subsequent installations.
Important! Downloading pax files for the SMP/E installation as part of the Pax-Enhanced ESD process requires write authority to the UNIX System Services (USS) directories that are used for the ESD process.
If you prefer not to involve all CA Technologies product installers with z/OS UNIX System Services, assign a group familiar with USS to perform Steps 1 through 4 and provide the list of the unpacked MVS data sets to the product installer. USS is not required for the actual SMP/E RECEIVE of the product or for any of the remaining installation steps.
To install files using Pax-Enhanced ESD, use the following process:
- Allocate and mount the file system. This process requires a USS directory to receive the pax file and to perform the unpack steps. We recommend that you allocate and mount a file system that is dedicated to Pax-Enhanced ESD and create the directory in this file system. Ensure that all users who will be working with pax files have write authority to the directory.
- Copy the product pax files into your USS directory. To download files, choose one of the following options:
- Download a zip file from CA Support Online to your PC, unzip the file, and then upload the product pax files to your USS file system.
- FTP the pax files from CA Support Online directly to your USS directory.
Note: Perform Steps 3 through 6 for each pax file that you upload to your USS directory.
- Create a product directory from the pax file. Set the current working directory to the directory containing the pax file, and create a directory in your USS directory by entering the following command:
pax -rvf pax-filename
- Use the SMP/E GIMUNZIP utility to create z/OS installation data sets. The file UNZIPJCL in the directory that the pax command created in Step 3 contains a sample JCL to GIMUNZIP the installation package. Edit and submit the UNZIPJCL JCL.
- Receive the SMP/E package. Use the data sets that GIMUNZIP created in Step 4. Perform a standard SMP/E RECEIVE using the SMPPTFIN and SMPHOLD (if applicable) DASD data sets. Also, specify the high-level qualifier for the RELFILEs on the RFPREFIX parameter of the RECEIVE command.
- Proceed with product installation. Consult product-specific documentation, including AREADME files and installation notes to complete the product installation.
- (Optional) Clean up the USS directory. Delete the pax file, the directory that the pax command created, all of the files in it, and the SMP/E RELFILEs, SMPMCS, and HOLDDATA data sets.
More Information:
USS Environment Setup
Allocate and Mount a File System
Copy the Product Pax Files into Your USS Directory
Create a Product Directory from the Pax File
Copy Installation Files to z/OS Data Sets
Copyright © 2012 CA.
