Installing Your Product from Pax-Enhanced ESD › Apply Maintenance
Apply Maintenance
CA Support Online has maintenance and HOLDDATA published since the installation data was created. After the maintenance process completes, the product is ready to deploy.
- Check CA Support Online and download any PTFs and HOLDDATA published since this release was created. If the base release was created recently, no PTFs or HOLDATA will have been published yet.
- Transfer the downloaded files to two separate FB 80 sequential data sets. Use one data set to contain the PTFs and the other to contain the HOLDDATA.
The PTFs and HOLDDATA become accessible to the yourHLQ.SAMPJCL maintenance members.
- The PANSEDIT macro was customized in the installation steps. Verify that you still have the values from the base installation.
- Open the SAMPJCL member PAN6RECP in an edit session and execute the PANSEDIT macro from the command line.
PAN6RECP is customized with your JOB statement, CSI location, and zone names.
- Customize the PAN6RECP SMPPTFIN and SMPHOLD DD statements to reference the FB 80 data sets for the PTFs and HOLDDATA.
- Submit PAN6RECP.
The PTFs and HOLDDATA are received.
- Open the SAMPJCL member PAN7APYP in an edit session and execute the PANSEDIT macro from the command line.
PAN7APYP is customized.
- Submit PAN7APYP.
The PTFs are applied.
- (Optional) Open the SAMPJCL member PAN8ACCP in an edit session and execute the PANSEDIT macro from the command line.
PAN8ACCP is customized.
- (Optional) Submit yourHLQ.SAMPJCL member PAN8ACCP.
The PTFs are accepted.
Note: You do not have to submit the job at this time. You can accept the PTFs according to your site policy.
Note: We recommend that you check for available maintenance; however, you may find that none is available.
Copyright © 2012 CA.
