To simplify the process, the PDF version of this guide includes a sample JCL job that you can copy directly to the mainframe. To access this job, click the paper clip icon at the left of the PDF reader. A window displaying attachments opens. Double-click the UnloadJCL.txt file to view the sample JCL job.
Note: The sample JCL to install the product is also provided in the CAI.SAMPJCL library on the distribution tape.
//COPY EXEC PGM=IEBCOPY,REGION=4096K //SYSPRINT DD SYSOUT=* //SYSUT1 DD DSN=CAI.SAMPJCL,DISP=OLD,UNIT=unitname,VOL=SER=nnnnnn, // LABEL=(1,SL) //SYSUT2 DD DSN=yourHLQ.SAMPJCL, // DISP=(,CATLG,DELETE), // UNIT=sysda,SPACE=(TRK,(15,3,6),RLSE) //SYSUT3 DD UNIT=sysda,SPACE=(CYL,1) //SYSIN DD DUMMY
Specifies the tape unit to mount the tape.
Specifies the tape volume serial number.
Specifies the data set prefix for the installation.
Specifies the DASD where you want to place the installation software.
The SAMPJCL data set is created and its contents are downloaded from the tape.
Copyright © 2012 CA.
