Important! This procedure is optional. Do not use this procedure until you complete the entire installation process.
To free file system disk space for subsequent downloads after downloading and processing the pax files for your CA Technologies product, we recommend removing the files from your USS directory and deleting unnecessary MVS data sets. You can delete the following items:
These data sets have the HLQ that you assigned in the UNZIPJCL job.
Note: Retain non-SMP/E installation data sets such as yourHLQ.INSTALL.NOTES for future reference.
Your view is of the applicable USS directory.
rm paxfile
Specifies the name of the CA Technologies pax file that you downloaded.
The pax file is deleted.
rm -r product-specific_directory
Specifies the product-specific directory that the pax command created.
The product-specific directory is deleted.
Note: You can also use TSO ISHELL to navigate to the pax file and product-specific directory, and delete them using the D line command.
Note: We recommend that you check for available maintenance; however, you may find that none is available.
Copyright © 2010 CA.
