The Move Request purge programs (APCS5950 and APCS5955) can be used together with a CA PanAPT history file to migrate old Move Requests from the pending file. However, use of these programs and the creation of the history VSAM file are optional.
In Phase One, you modified the installation JCL and chose whether to create the APTHIST file. You must have a created history file to implement the Purge Move Requests feature.
Make sure that CABYPROC member APJPBKUP agrees with your decision about the history file. In Phase Two, Step 8, you edited CABYPROC members. Therefore, you should have set the HISTFL= parm in APJPBKUP to zero if you are implementing the Purge Move Request feature or to one if you are not.
Copyright © 2010 CA.
