Enter CA PanAPT by executing the APT CLIST that is delivered with the CA PanAPT system. This CLIST allocates the CA PanAPT system libraries (with the installation defaults specified in the CLIST) and passes control to APCS1000, the main online CA PanAPT module. When you exit CA PanAPT, the CLIST will deallocate the system libraries. Using this APT CLIST lets you switch to an alternate CA PanAPT system (if you are using more than one) when you enter CA PanAPT.
You can speed up the performance of entering CA PanAPT (but also limit your flexibility of being able to switch CA PanAPT systems on demand) by making the following changes:
//APTDB DD DISP=SHR,DSN=<VPFX>.APTDB //APTMODEL DD DISP=SHR,DSN=<SPFX>.CABYDATA
A,'PGM(APCS1000) NEWAPPL(APT) PARM(&ZTRAIL) NOCHECK'
Copyright © 2010 CA.
