Preparing to Start Your Product › Complete Installation Checklist › Edit Members in CABYPARM (CA Panvalet Users Only)
To edit members in CABYPARM
- Modify member APJRRDSN.
- Change <PVLOAD> to the data set name of your CA Panvalet load library.
- Change <APTLOAD> to the data set name of your CA PanAPT load library.
- Modify member APJR5423.
- Change <PVVERSION> to the version of CA Panvalet you have installed. This should be in the format VV.R where VV is the version and R is the release, for example 14.2.
- Change <MDSCB> to the name of your model DSCB used to create new generations of a GDG (as described in Step 4 of Phase One of the installation).
- Review the REXX variables and change them if necessary.
Copyright © 2010 CA.
