Preparing to Start Your Product › Verify Installation Checklist › Verify Batch System
Verify Batch System
To verify batch system portion of CA PanAPT
- Run job APJJ5310 from CABYJCL to select the Move Request you created.
If the Move Request is not selected, make sure its status is Approved for QA. Only approved Move Requests can be selected. Also make sure the next move date is the current date or earlier, or blank. Make any necessary corrections to the Move Request and rerun APJJ5310.
- Run job APJJ5320 from CABYJCL to move the members in the selected Move Request.
- Approve the Move Request for production and rerun the above two steps if your Move Request now needs to be moved to production (that is, you are using QA libraries).
- If you specified to delete members from old libraries following a move, verify that the members have been moved to the production libraries and deleted from the old libraries by reviewing the job output and directory listings of the libraries.
When you complete this step, the installation process is complete.
Copyright © 2010 CA.
