Many of the modifications you perform during installation and implementation involve changing all occurrences of certain character strings. We recommend that you set up PF keys to perform CHANGE commands using < and > signs.
To change the following strings
Note: The previous three prefixes can be the same. There is no requirement that they be different.
Copyright © 2010 CA.
