Previous Topic: Implement External Security RulesNext Topic: CA PanAPT/UIF Security
CA PanAPT Activity Access
When users attempt functions in CA PanAPT, CA PanAPT validates external security first (and if authorization is granted) then validates the internal security system (set up through Control File Maintenance). If authorization is not granted during external security validation, a security error appears and the function is not allowed.
Set up security rules as defined in the following table and set up permits (as applicable) according to your site standards.
An example of a Standard Security Facility (SSF) rule follows:
PANAPTF.system-id.CTLSYS.SYSINFO.CHG
where:
Activity Name
Description and SSF Rule
CTL/ENTRY
Control file maintenance entry:
CTLACT/CHG
Control file activity change:
PANAPTF.system-id.CTLACT.activity-name.CHG
CTLACT/INQ
Control file activity inquire:
PANAPTF.system-id.CTLACT.activity-name.INQ
CTLSYS/ADD
Control file system information add (for adding CA Pan/LCM Configuration Manager Option information):
PANAPTF.system-id.CTLSYS.ACCSMTHD.ADD
PANAPTF.system-id.CTLSYS.CONFIG.ADD
CTLSYS/CHG
Control file system information change:
PANAPTF.system-id.CTLSYS.SECURITY.CHG
PANAPTF.system-id.CTLSYS.VERPROCS.CHG
PANAPTF.system-id.CTLSYS.LIBLEVEL.CHG
PANAPTF.system-id.CTLSYS.ACCSMTHD.CHG
PANAPTF.system-id.CTLSYS.CONFIG.CHG
CTLSYS/DEL
Control file system information delete (for deleting CA Pan/LCM Configuration Manager Option information):
PANAPTF.system-id.CTLSYS.ACCSMTHD.DEL
PANAPTF.system-id.CTLSYS.CONFIG.DEL
CTLSYS/INQ
Control file system information inquire:
PANAPTF.system-id.CTLSYS.SYSINFO.INQ
PANAPTF.system-id.CTLSYS.SECURITY.INQ
PANAPTF.system-id.CTLSYS.VERPROCS.INQ
PANAPTF.system-id.CTLSYS.LIBLEVEL.INQ
PANAPTF.system-id.CTLSYS.ACCSMTHD.INQ
PANAPTF.system-id.CTLSYS.CONFIG.INQ
CTLUSER/ADD
Control file user ID add:
PANAPTF.system-id.CTLUSER.user‑id.ADD
CTLUSER/CHG
Control file user ID change:
PANAPTF.system-id.CTLUSER.user‑id.CHG
CTLUSER/DEL
Control file user ID delete:
PANAPTF.system-id.CTLUSER.user‑id.DEL
CTLUSER/INQ
Control file user ID inquire:
PANAPTF.system-id.CTLUSER.user‑id.INQ
DEV/ENTRY
Development facility entry:
PANAPTF.system-id.DEV
DEV/MM
Development modify members command:
PANAPTF.system-id.DEV.MM
DEV/PRINTTBL
Development print move request member table:
PANAPTF.system-id.DEV.PRINTTBL
DEVADMIN/ENTRY
Project administration entry:
PANAPTF.system-id.DEVADMIN
INVENTRY/ADD
Inventory add:
PANAPTF.system-id.INVENTRY.name.ADD
INVENTRY/APP
Inventory approve:
PANAPTF.system-id.INVENTRY.name.APP
INVENTRY/ASN
Inventory assign:
PANAPTF.system-id.INVENTRY.name.ASN
INVENTRY/CHG
Inventory change:
PANAPTF.system-id.INVENTRY.name.CHG
INVENTRY/DEL
Inventory delete:
PANAPTF.system-id.INVENTRY.name.DEL
INVENTRY/ENTRY
Inventory maintenance entry:
INVENTRY/INQ
Inventory inquire:
PANAPTF.system-id.INVENTRY.name.INQ
INVENTRY/REL
Inventory release:
PANAPTF.system-id.INVENTRY.name.REL
INVENTRY/RET
Inventory assign and retrieve:
PANAPTF.system-id.INVENTRY.name.RET
INVENTRY/TRN
Inventory transfer:
PANAPTF.system-id.INVENTRY.name.TRN
LIBCODE/ADD
Library code add:
PANAPTF.system-id.LIBCODE.libcode/subcode.ADD
LIBCODE/CHG
Library code change:
PANAPTF.system-id.LIBCODE.libcode/subcode.CHG
LIBCODE/COP
Library code copy:
PANAPTF.system-id.LIBCODE.libcode/subcode.COP
LIBCODE/DEL
Library code delete:
PANAPTF.system-id.LIBCODE.libcode/subcode.DEL
LIBCODE/ENTRY
Library code maintenance entry:
LIBCODE/INQ
Library code inquire:
PANAPTF.system-id.LIBCODE.libcode/subcode.INQ
LIBCODE/SECURITY
Library code view security codes:
PANAPTF.system-id.LIBCODE.libcode/subcode.SECURITY
MEMBER/BROWSE
Browse a member:
PANAPTF.system-id.MEMBER.member‑name.BROWSE
MEMBER/CHECKIN
Checkin a member:
PANAPTF.system-id.MEMBER.member‑name.CHECKIN
MEMBER/CHECKOUT
Checkout a member:
PANAPTF.system-id.MEMBER.member‑name.CHECKOUT
MEMBER/COMPARE
Compare members:
PANAPTF.system-id.MEMBER.member‑name.COMPARE
MEMBER/COMPILE
Compile a member:
PANAPTF.system-id.MEMBER.member‑name.COMPILE
MEMBER/COMPLINK
Compile and link a member:
PANAPTF.system-id.MEMBER.member‑name.COMPLINK
MEMBER/EDIT
Edit a member:
PANAPTF.system-id.MEMBER.member‑name.EDIT
MEMBER/HISTORY
View member history:
PANAPTF.system-id.MEMBER.member‑name.HISTORY
MEMBER/LINK
Link edit a member:
PANAPTF.system-id.MEMBER.member‑name.LINK
MEMBER/LISTING
View a member's output listing:
PANAPTF.system-id.MEMBER.member‑name.LISTING
MEMBER/MERGE
Merge members:
PANAPTF.system-id.MEMBER.member‑name.MERGE
MEMBER/OUTPUTCP
View member compare output:
PANAPTF.system-id.MEMBER.member‑name.OUTOUTCP
MEMBER/OUTPUTMG
View member merge output:
PANAPTF.system-id.MEMBER.member‑name.OUTOUTMG
MEMBER/UTILITY
Member utilities:
PANAPTF.system-id.MEMBER.member‑name.UTILITY
MEMBER/XIR
View member cross reference:
PANAPTF.system-id.MEMBER.member‑name.XIR
MOVEREQ/ADD
Move request add:
PANAPTF.system-id.MOVEREQ.number.ADD
MOVEREQ/APB-short-name
Move request approve for back out at level short-name:
PANAPTF.system-id.MOVEREQ.number.APB-short-name
MOVEREQ/APM-short-name
Move request approve for move at level short-name:
PANAPTF.system-id.MOVEREQ.number.APM-short-name
MOVEREQ/BAK
Move request back out:
PANAPTF.system-id.MOVEREQ.number.BAK
MOVEREQ/BRO
Move request browse:
PANAPTF.system-id.MOVEREQ.number.BRO
MOVEREQ/CHG
Move request change (for move requests being created):
PANAPTF.system-id.MOVEREQ.number.CHG
MOVEREQ/CHGAWAPP
Move request change (for move requests awaiting approvals):
PANAPTF.system-id.MOVEREQ.number.CHGAWAPP
MOVEREQ/CLO
Move request close:
PANAPTF.system-id.MOVEREQ.number.CLO
MOVEREQ/CLOASSGN
Move request assignment test at close:
PANAPTF.system-id.MOVEREQ.number.CLOASSGN
MOVEREQ/COP
Copy move request:
PANAPTF.system-id.MOVEREQ.number.COP
MOVEREQ/CR
Copy a move request for rework:
PANAPTF.system-id.MOVEREQ.number.CR
MOVEREQ/DAT
Move request change date:
PANAPTF.system-id.MOVEREQ.number.DAT
MOVEREQ/DEL
PANAPTF.system-id.MOVEREQ.number.DEL
MOVEREQ/DELCLOSD
Move request delete (for closed move requests):
PANAPTF.system-id.MOVEREQ.number.DELCLOSD
MOVEREQ/ENTRY
Move request maintenance entry:
MOVEREQ/INQ
Move request inquire:
PANAPTF.system-id.MOVEREQ.number.INQ
MOVEREQ/MEMBER
Move request member add:
PANAPTF.system-id.MOVEREQ.number.MEMBER.member-name
MOVEREQ/MEMCHG
Move request member change:
PANAPTF.system-id.MOVEREQ.number.MEMCHG.member-name
MOVEREQ/MEMDEL
Move request member delete:
PANAPTF.system-id.MOVEREQ.number.MEMDEL.member-name
MOVEREQ/MEMPURGE
Move request member purge:
PANAPTF.system-id.MOVEREQ.number.MEMPURGE.member-name
MOVEREQ/PRT
Move request print:
PANAPTF.system-id.MOVEREQ.number.PRT
MOVEREQ/RVP
Move request run verification:
PANAPTF.system-id.MOVEREQ.number.RVP
MOVEREQ/STA
Move request status:
PANAPTF.system-id.MOVEREQ.number.STA
PROJECT/ADD
Add a project:
PANAPTF.system-id.PROJECT.project.ADD
PROJECT/CHG
Change a project:
PANAPTF.system-id.PROJECT.project.CHG
PROJECT/DEL
Delete a project:
PANAPTF.system-id.PROJECT.project.DEL
PROJECT/INQ
Project inquiry:
PANAPTF.system-id.PROJECT.project.INQ
REPORT/APCS5105
Online approval group cross reference report:
PANAPTF.system-id.REPORT.APCS5105
REPORT/APCS5104
Online approval category cross reference report:
PANAPTF.system-id.REPORT.APCS5104
REPORT/APCS6111
Online assignment report:
PANAPTF.system-id.REPORT.APCS6111
REPORT/ENTRY
Online report entry:
USERLIB/CHG
Change user work libraries:
PANAPTF.system-id.USERLIB.user‑id.CHG
USERLIB/INQ
User work library inquiry:
PANAPTF.system-id.USERLIB.user‑id.INQ
