The following table summarizes information about CA PMO commands:
Disables CA PMO, prevents you from using PMOMON, and prevents CA PMO from reusing its ECSA the next time it is started.
Causes CA PMO to report on whether the specified library is being managed, whether it is a private or LNKLST library, and whether it has been excluded from management. If no volser is specified, CA PMO reports on the status of all libraries having data set name. Also displays names of all private libraries CA PMO manages (MANAGED) and names of all candidate libraries (CANDIDATES).
Tells PMO/XSYS to write to and read from the control file every x seconds, where 10 < = x > = 1.
Performs one or more of the following functions:
Turns tracing on for the CA PMO DFDSS exit processing area.
Excludes one or all LNKLST libraries from CA PMO management.
Stops CA PMO from managing one or all private libraries. CA PMO can produce an offline report that lists all members (AM) of the hash table, prints only the summary section (NM) of the report, or produces no report at all (NR). The hash table can be sorted alphabetically by member name (SA) or numerically by resolution count (SN).
Changes the status of the CA PMO>/FDR interface.
Causes CA PMO to start managing one or all LNKLST libraries that had been excluded.
Causes CA PMO to start managing a new private library.
Deletes the entry of the specified LNKLST member from the managed list.
F PMO,OFFCHECK
Displays volumes that you have excluded from CA PMO management.
Removes volumes from CA PMO management.
Makes volumes reeligible for CA PMO management.
Produces an offline report for one or all managed private libraries. The report can list all members (AM) of the hash table, or print only the summary section (NM) of the report. The hash table can be sorted alphabetically by member name (SA) or numerically by resolution count (SN).
Resets all of CA PMO statistics and clears the candidate list.
Resets the CA PMOcandidate list.
Resets the CA PMO peak interval statistics.
Resumes update detection of the specified library or all LNKLST libraries.
Changes the destination of report output when writing to a data set.
Checks the CA PMO activity status.
Prevents updates to a specified library or all LNKLST libraries managed by CA PMO.
Controls the destination of report output.
Turns on internal CA PMO tracing.
Disables CA PMO.
Starts CA PMO and optionally formats the PMO/XSYS control file.
Copyright © 2011 CA.
