Previous Topic: Deleting and Reallocating Libraries Under DFHSMNext Topic: Copying Library Members
Compressing a Managed Library
When you compress a library that CA PMO manages, follow this procedure:
If you fail to follow this procedure, you may receive an abend for the batch job, TSO session, or started task that initiates a directory search of the compressed library. The abend occurs during the compress or shortly afterwards. If the library is compressed with DISP=SHR, an abend can occur even if CA PMO is not running. Possible abends include S106 and S806.
LNKLST Libraries
If you compress a LNKLST library, CA PMO deletes all managed list entries for the compressed library and all entries following the compressed library in the LNKLST concatenation. The update is propagated cross-system if PMO/XSYS is in use.
To avoid the loss of managed list entries, you can control the process by adding a //NOREFPMO DD DUMMY statement to the compress JCL to have CA PMO ignore the update.
When compressing a LNKLST library, you must ensure that:
