Previous Topic: Cross-System UpdatesNext Topic: Deleting and Reallocating an Automatically Managed Library
Deleting and Renaming Managed Private Libraries
Whenever you delete or rename a library, regardless of whether CA PMO is managing it, follow this procedure:
  1. Stop all batch jobs, TSO sessions, and started tasks that have opened the library (except for CA PMO).
  2. Delete or rename the library (if you plan on moving it, you must then reallocate it).
  3. Restart the jobs, sessions, or started tasks that you stopped.
When you delete or rename a library that CA PMO manages, CA PMO detects the update and temporarily stops managing the library. CA PMO may issue an offline report for the library depending on the value you specified for the EXCLREPT parameter. Messages PMO370I and PMO396I are written to your system log.
Notes:
