There are essentially two kinds of updates: updates to libraries and updates to members of those libraries.
Updates to library members include the following activities:
When you update a member of a library, its location on DASD—that is, its TTR—might change. Since the TTR is stored in the directory entry for that member, the update invalidates the member entry in the CA PMO software cache or LLA. CA PMO automatically detects member updates. When an update is detected, CA PMO modifies the member entry in the managed list or hash tables (as appropriate) to reflect the update. If you have not turned off LLA, CA PMO also can automatically refresh LLA after LNKLST updates, depending on the value that you specified for the LLA parameter.
Certain kinds of updates affect entire libraries. These updates include the following activities:
The way CA PMO handles library and member updates depends on whether the update occurs on the system where CA PMO is running, or if it occurs on a different system. These issues are discussed on the following pages.
Copyright © 2011 CA.
