The SYSOUT command controls the destination of report output.
The SYSOUT command has the following syntax:
F PMO {,SYSOUT=class}
{,SYSOUT=DS}
This command has the following operands:
The CA PMO keyword.
You specify this operand as follows:
Tells CA PMO to write reports to the specified SYSOUT class.
Tells CA PMO to write reports to the data set name specified on the RPTDSN parameter (which you can override with the RPTDSN command).
Note: If you issue the RPTDSN command, the SYSOUT class is automatically changed to DS and you do not need to use this command.
Copyright © 2011 CA.
