The STAT command determines whether CA PMO is active, the status of PMO/XSYS on each system, and the status of all the PMO/XCF members in the XCF group.
The STAT command has the following syntax:
F PMO,STAT
This command has the following operands:
The CA PMO keyword.
Checks CA PMO status.
CA PMO responds with any of the following messages:
PMO001I CA PMO r.v SERVICE PACK n ACTIVE
PMO706I PMO/XSYS ON SYSTEM ssss ACTIVE
NOT STARTED
STOPPED
ABENDED
INACTIVE
The ssss variable represents the system ID for each system running PMO/XSYS.
PMO808I PMO/XCF MEMBER mmmmmmmmmmmmmmmm ON SYSTEM ssssssss CREATED
ACTIVE
QUIESCED
FAILED
UNKNOWN
IN GROUP gggggggg
The mmmmmmmmmmmmmmmm variable represents the member name, the ssssssss is the system ID for each system running with the PMO/XCF component in the XCF gggggggg.
Copyright © 2011 CA.
