The CYCLE command changes the time interval that PMO/XSYS writes to (and reads from) the control file.
The CYCLE command has the following syntax:
F PMO,CYCLE=x
This command has the following operands:
The CA PMO keyword.
You specify this operand as follows:
Tells PMO/XSYS to write to (and read from) the control file every x seconds, where 10 = x = 1. Lower this value only if you feel it is taking too long for updates to be migrated across systems.
Copyright © 2011 CA.
