Previous Topic: RPTDSN ParameterNext Topic: SVCCPU Parameter
SUSPREF Parameter
Tells CA PMO not to refresh LLA for the specified data set. You can use this parameter to control when specific LNKLST libraries are refreshed. For example, you may want all updates to take effect only at the end of the day.
Note: If you do not run LLA, this parameter has no effect.
Format
The SUSPREF parameter has the following syntax:
SUSPREF=data set name
where data set name has one of following values:
data set name
Tells CA PMO to ignore all updates for data set name. Data set name must be a LNKLST library.
LNKLST
Tells CA PMO to ignore all updates for all LNKLST libraries. LLA will not be refreshed. Updates will be communicated to other systems.
Default: None.
