The amount of time that CA PMO spends when it collects data for its current and peak interval statistics. The current interval is the most recent period of CA PMO active time. The peak interval is the period with the most directory search activity. CA PMO measures these intervals from the time it becomes active, or from the time that you last reset its statistics with the F PMO,RESET command, or since midnight (if you specify the parameter RESETPK=YES).
The INTVL parameter has the following syntax:
INTVL=interval length
The INTVL parameter requires the following value:
The time interval in hours, minutes, and seconds. You specify the time in numeric format, for instance, 02:30:00. CA PMO uses this amount of time when it calculates current and peak interval statistics for the D5 display. CA PMO rounds the time interval to the nearest ten minutes.
Values of less than ten minutes are rounded up to ten minutes.
Default: INTVL=01:00:00
Copyright © 2011 CA.
