Previous Topic: INCLAUTO ParameterNext Topic: INCLPRVT Parameter
INCLLNK Parameter
Specifies a particular set of LNKLST libraries that CA PMO will manage in the managed list. This parameter is mutually exclusive with the EXCLLNK parameter. If you do not specify an INCLLNK or EXCLLNK parameter, CA PMO manages all of your LNKLST libraries.
Format
The INCLLNK parameter has the following syntax:
INCLLNK=data set name
Valid INCLLNK data set name values:
data set name
The name of a LNKLST library that should be managed in the managed list. To include more than one LNKLST library, specify a separate INCLLNK=data set name statement for each library.
Includes all LNKLST library members in the managed list.
Default: All LNKLST libraries are included for management
Examples
INCLLNK=SYS1.CMDLIB
INCLLNK=*
Note: Do not code any other parameters on a statement that contains the INCLLNK parameter.
