Specifies the private libraries that CA PMO will not manage automatically.
The EXCLAUTO parameter has the following syntax:
EXCLAUTO=data set name,VOL=volser
The EXCLAUTO parameter requires one of following values:
The name of a private library, or a set of private libraries, that you want to prevent CA PMO from managing automatically. You can use an asterisk (*) as a wildcard for one character. If used at the end of the data set name, this character can signify multiple characters. You can specify more than one EXCLAUTO=data set name statement in your parameter data set.
Excludes all libraries from the specified volume.
The serial number of a particular volume. To specify a set of volumes, you may use a prefix for a volume serial number and end the volser with an asterisk (*).
Excludes data set name from all volumes.
Default: No excluded libraries
Examples
EXCLAUTO=DSI*,VOL=MVS* EXCLAUTO=*,VOL=* EXCLAUTO=*,VOL=MVSDPM EXCLAUTO=DSA**11.PGM.*,VOL=TSU0**
Note: Keep the following items in mind when using the EXCLAUTO parameter:
Copyright © 2011 CA.
