This indicates whether CA PMO should perform priority management for MUST CACHE datasets.
The AUTOSMS parameter has the following syntax:
AUTOSMS=option
Where option is one of the following values:
PMO should perform priority management of SMS MUST CACHE datasets. Caution should be used when running with AUTOSMS set to YES, this may result in thrashing if your CA PMO parameters specify insufficient resources to handle the increase in library management.
Default: AUTOSMS=YES
PMO should not perform priority management of SMS MUST CACHE datasets.
Copyright © 2011 CA.
