You specify parameters for CA PMO in a data set. To simplify this task, you can use the data set PMO.CNTL(PMOPARMS), which was copied onto your system from the distribution tape. By default, the sample startup procedure in PMO.CNTL(PROCPMO) assumes that your parameter data set is named PMO.CNTL(PMOPARMS). As an alternative to using PMOPARMS, you can use any member of your system PARMLIB or any sequential data set on DASD where LRECL has a value of 80 and BLKSIZE has a value of a multiple of 80.
Copyright © 2011 CA.
