Previous Topic: Install a ProductNext Topic: Deploy the Product to the Destination System
Maintain the Installed Products
You can migrate existing SMP/E environments into CA CSM to maintain all your installed products in a unified way from a single web-based interface.
You can use CA CSM to maintain a CA Technologies product.
You perform the following high-level tasks to maintain a product using CA CSM:
  1. Verify that CA CSM recognizes the SMP/E environment where your product is installed. If not, migrate the SMP/E environment to CA CSM.
    During the migration, CA CSM stores information about the SMP/E environment in the database.
  2. From the Product tab, download the latest maintenance for the installed product releases.
    If you cannot find the required release, perform the following steps to download the maintenance:
    1. Add the release manually.
    2. Update the release.
  3. Apply the maintenance.
    CA CSM applies the maintenance to your product.
After the maintenance process completes, the product is ready for you to deploy to systems that are defined in the system registry.
