You access CA CSM using the web-based interface.
You need the URL of CA CSM from the CA CSM administrator.
The login page appears.
Note: If the Notice and Consent Banner appears, read and confirm the provided information.
The initial page appears. If you log in for the first time, you are prompted to define your account on the CA Support Online website.
Note: For more information about the interface, click the online help link at the top right corner of the page.
You are prompted for the credentials to use on the CA Support Online website.
You are prompted to review your user settings.
Note: These settings are available on the User Settings page.
A dialog opens, which shows the progress of the configuration task. You can click Show Results to view the details of the actions in a finished task.
Important! If your site uses proxies, review your proxy credentials on the User Settings, Software Acquisition page.
