Previous Topic: Download Using Batch JCLNext Topic: Download Files to Mainframe through a PC
Example: CAtoMainframe.txt, JCL
The following text appears in the attached CAtoMainframe.txt JCL file:
//GETPAX   JOB (ACCOUNTNO),'FTP GET PAX ESD PACKAGE',
//          MSGCLASS=X,CLASS=A,NOTIFY=&SYSUID
//* This sample job can be used to download a pax file directly from  *
//* CA Support Online to a USS directory on your z/OS system.         *
//* When editing the JCL ensure that you do not have sequence numbers *
//* turned on.                                                        *
//* This job must be customized as follows:                           *
//* 1. Supply a valid JOB statement.                                  *
//* 2. The SYSTCPD and SYSFTPD JCL DD statements in this JCL may be   *
//*    optional at your site. Remove the statements that are not      *
//*    required. For the required statements, update the data set     *
//*    names with the correct site-specific data set names.           *
//* 3. Replace "Host" based on the type of download method.           *
//* 4. Replace "YourEmailAddress" with your email address.            *
//* 5. Replace "yourUSSpaxdirectory" with the name of the USS         *
//*    directory used on your system for Pax ESD downloads.           *
//* 6. Replace "FTP Location" with the complete path                  *
//*    and name of the pax file obtained from the FTP location        *
//*    of the product download page.                                  *
//GETPAX   EXEC PGM=FTP,PARM='(EXIT',REGION=0M
//SYSTCPD  DD   DSN=yourTCPIP.PROFILE.dataset,DISP=SHR
//SYSFTPD  DD   DSN=yourFTP.DATA.dataset,DISP=SHR
//SYSPRINT DD   SYSOUT=*
//OUTPUT   DD   SYSOUT=*
//INPUT    DD   *
Host
anonymous YourEmailAddress
lcd yourUSSpaxdirectory
binary
get FTP_location
quit
