Previous Topic: Install Your Product Using Pax ESD or DVDNext Topic: USS Environment Setup
How to Install Your Product Using a Pax File
As a system programmer, your responsibilities include installing products on your mainframe system. With this option, you acquire a product pax file from http://ca.com/support or from a product DVD.
The DVD contains a folder that includes the pax file for the product. Product updates may have occurred after you acquired the product DVD. The files on the online site always have the most current product updates. To determine if you have the latest updates, go to http://ca.com/support and click Download Center.
You perform the following tasks to install a product with a pax file:
This illustration shows the process of installing a product.
  1. Allocate and mount the file system.
  2. Acquire the product pax files.
  3. Create a product directory from the pax file.
  4. Copy the installation files to z/OS data sets.
  5. Prepare the SMP/E environment for a pax installation.
  6. Run the installation job for a pax installation.
  7. (Optional) Clean up the USS directory.
  8. Apply preventive maintenance.
