Previous Topic: WindowsNext Topic: Deployment Security
Unix/Linux/USS
If you install CA OM Web Services as root you run the Configuration Tools, run System Test Tools, and the Update Installer as root or using pseudo.
If you install CA OM Web Services as a non-super-user account you run the Configuration Tools, System Test Tools, and the Update Installer as a user, a member of a group who has access to the installed files, or root.
Note: For more information about security requirements on USS, see General USS Requirements.
