Previous Topic: InstallAnywhere Installation of CA OM Web Services on Other PlatformsNext Topic: Installation Logging
Installation Using the Console Mode
To install using the Console mode, follow these steps.
  1. Review the Introduction.
  2. Press Enter to continue.
  3. Review the License Agreements.
  4. Press Enter until you reach the end of the license agreement.
    You are prompted with the message:
    DO YOU ACCEPT THE TERMS OF THIS LICENSE AGREEMENT? (Y/N):
  5. Enter Y to accept the license agreement.
  6. Specify where you want to install CA OM Web Services.
    Do one of the following:
    This folder contains the files that are generated by the installer.
  7. Select the Java Virtual Machine you want the installed CA OM Web Services to use.
  8. Select Deployment Method.
    You can select CA OM Web Services to be deployed as either WAR or EAR file.
    Note: For more information about the correct format for the Java Web Application Server, see your Java Web Application Server documentation.
  9. Review the settings that are displayed in the Pre-Installation Summary.
  10. Press Enter.
  11. (Recommended) Select Whether to Launch Configuration Tool.
    Note:
  12. Review the Installation Complete Summary.
    Note: If your install had warnings or non-fatal errors, you receive a summary message that starts with Warning or Non-Fatal Failure. In this case, more information can be found in your install log, after finishing and closing the installer and optionally the Configuration Tool.
  13. Press Enter.
    Note: If you chose to Launch Configuration Tool, it starts in the same terminal. Instructions for the Configuration Tool are listed in a different section.
  14. Press Enter.
