On the Windows platform CA OM Web Services can be installed using a GUI.
This folder contains the files that the installer generates.
The installer searches for existing Java virtual machines (VMs) from default folders on the system. You can click Search Another Location… to search other folders or click Choose Java Executable… to select a particular Java executable.
You can select CA OM Web Services to be deployed as either a WAR or EAR file.
Note: For information about the correct format for your Java Web Application Server, see the Java Web Application Server documentation.
Note:
Note: If your install had warnings or non fatal errors then you receive a summary message that starts with Warning or Non Fatal Failure. In this case, more information can be found in your install log, after finishing and closing the installer.
Note: If you chose to Launch Configuration Tool, it pops up in a separate Window when the installer closes. Instructions for the Configuration Tool are listed in a different section.
