Previous Topic: Apply Fixes on Other PlatformsNext Topic: Update Installation Using the Console Mode
Update Installation Using the GUI Wizard
CA OM Web Services can be installed using the GUI (Graphic User Interface) mode.
  1. Select a locale from the Choose Locale drop-down menu, and click OK.
  2. Review the Introduction panel for information about the Installer and click Next.
  3. Specify the folder where you installed CA OM Web Services.
  4. According to the deployment method of your previous version of CA OM Web Services, do one of the following:
  5. The update installer backs up your original CA OM Web Services as a pair of WAR file. These files are placed into a folder that is specified in this panel.
    Note: The backup step is recommended. However, if you do not need a backup by the update installer, select "No backup." Ensure you have write permission to the backup folder. The update installer will also check whether this folder exists. If this folder does not exist, it will be created after installation starts.
  6. Review the settings that are displayed in the Pre-Installation Summary and click Install to start the Installation.
  7. Review the Install Complete Information.
    Note: If your install had warnings or non-fatal errors, you receive a summary message that starts with Warning or Non-Fatal Failure. In this case, more information can be found in your install log, after finishing and closing the installer.
  8. Click Done.
