Previous Topic: Distribution Libraries for MainframesNext Topic: InstallAnywhere based Install Requirements
DVD Space Requirements for Mainframes
Ensure that you have sufficient free space in the USS file system that you are using for Pax ESD to hold the directory that the pax command and its contents create. You need approximately 3.5 times the pax file size in free space.
If you do not have sufficient free space, you will receive error message EDC5133I.
