Previous Topic: Add Products to Monitor (CA Performance Center)Next Topic: Enable the Monitored Products' Collection Sources
Add Products to Monitor (CA NetQoS Performance Center)
You must add an instance of CA Network Flow Analysis for CA Anomaly Detector to monitor. You also have the option to add any other products that you want to monitor for anomalies. This topic describes how to complete this task in a CA NetQoS Performance Center deployment.
  1. Log in to the CA NetQoS Performance Center Console as a user with administrator privileges, if you are not already logged in.
  2. Click Admin, Product Settings: Name of the CA Anomaly Detector instance.
    The Monitored Products page opens with the View Monitored Products tab displayed.
  3. Click New.
    The New Monitored Product page opens.
  4. Add CA Network Flow Analysis as a monitored product: Specify values for the following options:
    Type
    Select the product name from the list: ReporterAnalyzer.
    If ReporterAnalyzer is not listed, verify that you have not already registered a CA Network Flow Analysis instance as a monitored product. You can register only one instance of CA Network Flow Analysis to a single instance of CA Anomaly Detector.
    IP Address
    Enter the IP address of the CA Network Flow Analysis server.
  5. Click Save.
    The Monitored Products page now shows the instance of CA Network Flow Analysis that you added. All of the currently configured Harvesters are added as potential data collectors on the Collection Sources tab, but the Harvesters are not enabled at this point.
  6. (Optional) Add another monitored product: Repeat the previous two steps until you have all of the monitored products you need.
    The list of monitored products page is updated to show your changes. CA Anomaly Detector contacts the product to add the collection sources to the View Collection Sources tab.
