Previous Topic: CA Application Delivery Analysis SensorsNext Topic: Refused Sessions
Retransmission Time
The Retransmission Time sensor looks for patterns in retransmissions.
TCP retransmission behavior has a significantly negative effect on application performance and network use. Communication across the affected connection can slow to a halt until a missing segment is retransmitted successfully. Only a limited number of missing segments can remain outstanding at any time.
Troubleshooting a Retransmission Time Alert
An anomaly in retransmission delay typically is caused by several critical components:
Identify sources of packet loss along the traffic paths. Keep in mind that the paths going to the server may be different from the paths coming from the server. If that is the case, analyze all paths.
