Previous Topic: White ListNext Topic: Configure Sensor Thresholds and Options
Absolute Thresholds
You have the option to set an absolute threshold so that alerts are generated when the threshold is violated, provided that alerts are enabled. Absolute thresholds are applied before probability thresholds.
The following table lists the sensors and units of measure for absolute thresholds.
Sensor
Looks For:
Unit of Measure
Buffer Misses
Pattern in buffer misses
buffer misses
Congestion Sources
Sources of overloading based on ICMP Source Quench
flows
Destination Unreachable Sources
High-volume sources of network, host, or port unreachable messages
host or port unreachable messages
Dropped Packets
Pattern in queue drops
dropped packets
Fragmented Packet Sources
Large sources of fragmented packets
fragmented packets
Frags And Loss Sources
Sources of fragmentation and packet loss
flows
High and Variable Vol-In
Highest-volume and variability destinations
bytes in
High and Variable Vol-Out
Highest-volume and variability sources
bytes out
High Flow Sources
Top sources of data flows
flows
High Packet Fan Out
Sources of the largest fan-out traffic patterns
destination hosts
Incoming Discard Rate
Pattern in incoming discards
discard rate
Incoming Error Rate
Pattern in incoming errors
error rate
Large DNS Packet Sources
Large sources of DNS packets that are larger than normal
flows
Large ICMP Packet Sources
Large sources of ICMP packets that are larger than normal
flows
Non-local Sources
Top sources of non-local traffic
non-local traffic
Packet Load
Pattern in bytes per packet to server
bytes per packet
Previously Null Routed Srcs
Hosts with high volumes of traffic that is no longer null-routed
flows
Refused Sessions
Pattern in refused sessions
percent
Retransmission Time
Pattern in retransmissions
seconds
RST-Only Sources
Highest-volume sources of RST-only flows
flows
SYN/RST-Only Packet Srcs
Highest-volume sources of SYN/RST-only flows
flows
SYN-Only Packet Sources
Highest-volume sources of SYN-only flows
flows
TTL Expired Sources
High-volume sources of TTL expired packets
flows
Voice Call DoS
DoS in voice calls
calls per minute
Voice Call Fan Out
Pattern in fan-out of voice calls
call ratio
Voice Server Distress
Call Server Distress
Volume Weighted Error Ratio
