Installation and Upgrade › Upgrade CA Anomaly Detector
Complete the steps in this topic to upgrade CA Anomaly Detector on a Windows server or virtual machine.
If the CA Anomaly Detector and any related software components are co-installed, upgrade the software in the order described in Co-Installation. The upgrade steps are written with the expectation that you have already upgraded any related products that will be co-located with CA Anomaly Detector.
- Log in as a user who has administrator privileges for CA Network Flow Analysis.
- Verify that the ISO file is downloaded. The ISO file contains the ADSetup9.3.0.exe file--the Installation or upgrade program for CA Anomaly Detector.
Copy the ADSetup9.3.0.exe file to the CA Anomaly Detector installation server, even if you plan to install the software remotely.
- If the server will host any CA Network Flow Analysis software, install or upgrade the other software before you proceed.
- Double-click the ADSetup9.3.0.exe file in Windows Explorer.
The installation program opens.
- Verify that English is selected, then click OK.
The Prior Installation Detected message opens.
- Review the information, then click OK.
If the existing software version is not supported for upgrade, upgrade to the supported version.
If the existing version is supported for upgrade, the Welcome screen opens.
- Click Next.
The Pre-Installation Summary screen opens.
- Review the information, then click Install.
The Installing AD screen opens. When the upgrade is complete, the Install Complete screen opens.
- (Optional) If errors occurred during the upgrade, see the following logs for details:
- General installation log: <install_path>\AD_Install_<timestamp>
- Upgrade log: <install_path>\migrator\migrator.log
- Click Done in the Install Complete screen.
The program closes.
- (Optional) Verify that the services are running:
- Click Start, Programs, Administrative Tools, Services.
- Verify that the AD-related services have the status Started:
- CA NFA Host Resolver Service
- CA NFA Hunter Tracker Service
- NetQoS Mysql
- Verify that the software is upgraded to the correct version: To display the revision history and verify the current software version, complete the following substeps:
- Open a Command Prompt window
- Start MySQL by entering the following command:
mysql
- Display the revision history by entering the following command:
select * from revision_history
Next: Complete the post installation tasks.
