CA Anomaly Detector is highly scalable. The program does not retain a lot of data. It collects and analyzes only the results of data analysis from the data sources that it is configured to analyze.
The MySQL database does not become overloaded easily. For example, after several weeks of running CA Anomaly Detector at a large enterprise, the database growth rate was equivalent to 4 GB per year. The typical growth rate in testing is 160,000 database rows per day.
Although you can run CA Anomaly Detector with most Harvesters, some limitations apply. In our testing, the following configurations were the maximum configurations that had acceptable performance:
We support using a single instance of CA Anomaly Detector to monitor the following data sources:
